V
Vitaliy
Hello,
I am running the simple program from here (I included the code at the
end for convinience):
http://www.pages.drexel.edu/~kws23/tutorials/PICTutorial/PICTutorial.html
I believe this is the code from some textbook, as I have seen it on
other websites as well.
I would like to doublecheck if my logic is correct.
In the following:
delay clrf tmr0 ; clear TMR0, start counting
again btfss tmr0, 0 ; if bit 0 = 1
goto again ; no, then check again
btfss tmr0, 1 ; if bit 1 = 1
btfss tmr0, 2 ; if bit 2 = 1
btfss tmr0, 3 ; if bit 3 = 1
btfss tmr0, 4 ; if bit 4 = 1
btfss tmr0, 5 ; if bit 5 = 1
btfss tmr0, 6 ; if bit 6 = 1
btfss tmr0, 7 ; if bit 7 = 1
return ; else exit delay
1. It the following correct?
tmr0, 0 is true after 1 clock cycle
tmr0, 1 - 3
tmr0, 2 - 7
tmr0, 3 - 15
tmr0, 4 - 31
tmr0, 5 - 63
tmr0, 6 - 127
tmr0, 7 - 255
2. If I want the delay to last 5 clock cycles (for example) - do I
need to do the following? I tried running delay loop twice, and the
delay was indeed 2xdelay, but haven't tried the following yet.
delay1 clrf tmr0 ; clear TMR0, start counting
delay2 clrf tmr0 ; clear TMR0, start counting
delay3 clrf tmr0 ; clear TMR0, start counting
3. When doing question 1, shouldn't we account for the time it takes
to excecute an instruction (I guess we assume it takes 1 clock cycle
to excecute 'btfss' and 0 clock cycles to excecute 'goto'
instruction?
4. With PIC16F84A, TMR0 runs at 1/4 of crystal oscillator's speed and
then you need to use OPTION register to divide frequency (multiply
time) by 1/2(2), 1/4(4), etc. I could not run at 1/2(2), but all other
prescaler options worked fine. Any ideas why?
5. Going back to the previous question (q.4), I would like to have
higher frequency to have better resolution. I looked up on digikey's
website, and it looks like the highest I can have with PDIP package is
40MHz (which I think will be good enough for me). These are the
following chips that I was able to find: PIC18LF1220-I/P, PIC18LF1230-
I/P, PIC18LF1320-I/P, PIC18LF1330-I/P. A little bit of clarification:
I have Picstart Plus programmer with the latest firmware and would
like to use it without purchasing another one. I would like to
generate PWM signal w/ 50% duty cycle. I haven't gone through the
datasheet in details, but I think it should be doable. Any suggestions
to get the highest frequency?
Thanks,
Vitaliy
Clock.asm
; FILE: Clock.asm
; AUTH: (Your name here)
; DATE: (date)
; DESC: 1.0 - Internal timer, blink LED every 32.8 msec
; NOTE: Tested on PIC16F84-04/P.
; 4 MHz crystal yields 1 MHz internal clock frequency.
; "option" is set to divide internal clock by 256.
; This results in 1 MHz/256 = 3906.25 Hz or 256 usec.
; tmr0 bits 0 through 7 (255 decimal) is checked, thus yielding
; 255*256 usec = 65.28 msec delay loop
; REFs: Easy Pic'n p. 113
list p=16F84
radix hex
; cpu equates (memory map)
portB equ 0x06 ; (p. 10 defines port address)
tmr0 equ 0x01
org 0x000
start clrwdt ; clear watchdog timer
movlw b'11010111' ; assign prescaler, internal clock
; and divide by 256 see p. 106
option
movlw 0x00 ; set w = 0
tris portB ; port B is output
clrf portB ; port B all low
go bsf portB, 0 ; RB0 = 1, thus LED on p. 28
call delay
call delay
bcf portB, 0 ; RB0 = 0, thus LED off
call delay
call delay
goto go ; repeat forever
end
; at burn time, select:
; memory uprotected
; watchdog timer disabled
; standard crystal (4 MHz)
; power-up timer on
In the following:
tmr0, 1 - 3
tmr0, 2 - 7
tmr0, 3 - 15
tmr0, 4 - 31
tmr0, 5 - 63
tmr0, 6 - 127
tmr0, 7 - 255
instruction?
Thanks,
Vitaliy
Clock.asm
; FILE: Clock.asm
; DATE: (date)
list p=16F84
radix hex
tmr0 equ 0x01
org 0x000
option
call delay
call delay
call delay
call delay
end
; memory uprotected
; power-up timer on
