Martin
I am trying to build some projects with some pics.
I am self taught, and think I know the hardware end and C programing
fairly well.
But assembler is new to me, so I am trying to learn it.
Before I ask my specific questions, a general one:
Do you know of any general (or PIC targeted) assembly language
tutorials,
I have tried searching google, but tend to find lots of x86 tutorials
I am currently trying to go through MPLabs tutorials, but their first
example has brought up two questions.
(I have copied the example below my questions)
My first question is: the line
clrf WREG
clears the working register W if I understand correctly, where does the
abbreviation WREG come from, is it a convention (that I would be
unaware of)
Also, there is an instruction "clrw" which directly clears W, rather
than the more general "clrf"
why would that not be used.
The other question is: for the lines
clrf COUNT,A ; initialize counter
incf COUNT,F,A
movf COUNT,W,A ; increase count and
what is the "A"
As I understand it, the variable count will point to a register, which
holds the count, and F or W indicate the register to send the results
to, but what is the "A"
Thank you,
Martin Bakalorz
Snippet of assembler
;Start of main program
; The main program code is placed here.
Main:
; *** main code goes here ***
----> clrf WREG
movwf PORTC ; clear PORTC
movwf TRISC ; configure PORTC as all outputs
Init
----> clrf COUNT,A ; initialize counter
IncCount
----> incf COUNT,F,A
----> movf COUNT,W,A ; increase count and
movwf PORTC ; display on PORTC
call Delay ; go to Delay subroutine
goto IncCount ; infinite loop
Delay
movlw 0x40
movwf DVAR2,A ; set outer delay loop
DelayOuter
movlw 0xFF
movwf DVAR,A ; set inner delay loop
DelayInner
decfsz DVAR,F,A
goto DelayInner
decfsz DVAR2,F,A
goto DelayOuter
return
fairly well.
tutorials,
clrf WREG
unaware of)
incf COUNT,F,A
what is the "A"
Thank you,
Martin Bakalorz
Main:
----> clrf WREG
Init
IncCount
Delay
movlw 0x40
DelayOuter
movlw 0xFF
DelayInner
decfsz DVAR,F,A
goto DelayInner
decfsz DVAR2,F,A
goto DelayOuter
return
