Pete Shew
I am developing using an 16F877 with the EPE IceBreaker system (an
ICD) and I can't read the EEPROM. I can't even modify registers 18C
(EEADDR) and 18D (EEDATA) from program code, although I can modify
18A. I CAN modify 18C and 18D from the IceBreaker GUI, and display the
EEPROM contents.
Running the program with the debugger diabled shows the same symptoms
that I see in the debugger, from which I infer that the read is
failing then too.
Is this a feature of the IceBreaker system (maybe to prevent reading
of program flash and hacking their code)? Anyone had this problem
before?
Pete
EEPROM contents.
failing then too.
before?
Pete
