K
kell
I'm going to build a circuit that flashes a strobe rapidly. If anybody
would like to know why, look up "dreamachine." There was an article in
the New York Times recently about it. The classic dreamachine uses a
motor and rotating cylinder with a light bulb in it to flash at 10 Hz,
but it will be much easier just to use a strobe.
I just need to know the voltage and the joules for each flash of the
strobe so I can build a circuit. I may use this bulb:
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=FLT-8&type=store
Open to suggestions for better strobe bulbs in terms of durability,
because the device I build may go through hundreds of thousands of
flashes in its life, perhaps millions. But mostly I need to know
required voltage and energy per flash for the example flash tube, or
flash tubes in general.
