Hi.
I'll preface with the fact that I am an entomologist... I have a very basic knowledge of electronics. In other words, I know how to hook up jumper cables to my car battery, but that's about it.
I'm trying to build an insect trap with light that will turn on at dusk and turn off at dawn. It's possible to buy these all wired, but I need many and have a limited budget. I have a photoelectric switch that I purchased on amazon http://www.amazon.com/Amico-Photoelectric-Switch-Sensor-50mmx25mm/dp/B00BLZ93T2.
My power source is a 12V 18AH battery and the light is a 15w blacklight bulb. Hooking the bulb directly to the battery works. When I incorporate the switch into the circuit, the red light indicates that the switch is powered, but the sensor will not activate the switch. I adjust the potentiometer, but still nothing happens. There is a green light that indicates the sensor. I tried hooking it up both ways (light activated, and dark activated), but still nothing. I will say that when it is hooked up for dark activated, the lamp stays continuously unlit, and when it's hooked up for light activated, the lamp is continuously lit. I'm not sure if I just got a faulty sensor, or if there is something I am missing here. Should go for a more expensive switch? The reviews on amazon are great for this switch though, there's even a video explaining how to hook it up, but it doesn't seem to work for me.
Once I get this figured out, I would like to eventually incorporate a solar panel so that the battery gets charged during the day. The ultimate goal being a trap that can be set out for weeks at a time in remote areas and be completely self sufficient.
Any help on this is very much appreciated. I can provide pictures of how I have everything hooked up if that would help.
Thanks!
Marc
Thanks!
Marc
