Thanks so much for the quick response. Sorry for the delay. Family and travel issues popped up. And I can only work on this when the wife is asleep at night ;o)
Here’s what I’m working with:
Dayton DC Motor
12 Volt PM DC
HP. 1/35 RPM: 2350
FL AMPS: 3.70
Keyence Photoelectric switch. PR-MF Series
Power voltage: 10 to 30 VDC, including 10% ripple (P-P)
Control output: NPN or PNP Open controller, 30 V or less. 50 mA or less
A multimeter reading from the wires (brown & blue) from the photoelectric switch to the motor indicates 2-3 amps and upwards of 10-12 volts as I’m using a volt regulator to supply power. I’m experiencing the same results when connected to a 12 V battery.
I’ve tried smaller motors to trouble shoot. They began to work with the photoelectric sensor then all stopped working and emitted the same clicking noise. Feels like back EMF or something mucking up the works. I have tried an ice cube relay (not sure if I connected it properly and will try again). Would inserting a capacitor resolve? Any input is greatly appreciated?
