PHONO PREAMP IC NEEDED
JeffM
realInfo
Dave said:
I haven't seen a single IC which includes both the necessary gain
stage and the RIAA equalization. They may exist, of course (or could
be made from a programmable-analog part) but I haven't seen them in use.
The commonest approach seems to be to use a dual op amp per channel,
with the RIAA equalization curve being implemented via components in
one or both of the op amp feedback loops. The page at
http://sound.westhost.com/project06.htm shows one such design.
You might be able to do it with just one dual op amp (one stage per
channel).
There are many high-quality audio op amps (low noise, adequate drive
capacity and gain/bandwidth product) which can be used for this sort
of design.
ec
go to datasheetlocator.com under national semi you will find gabz of application on how to design things like that.
