philips tv 21PT128A/71R unstable B+ power supply
davenn
Hi abs
welcome to the forums :)
so what tests have you done so far to check the TV PSU ?
have you looked for a service manual or at least a schematic online ?
what voltage is the B+ supply supposed to be ?
what is it dropping to ?
is it pulsing or just only periodically firing up or not firing up at all ?
have you taken the back of and done any voltage checks ?
have you looked to see if there's any obvious damage to any components
like bulging electrolytic capacitors ?
there's a bunch of questions for you to answer so we all have at least a bit of a chance in helping you :)
cheers
Dave
i voltage checking..
i have no schematic diagram online or service manual..
the voltage is range at 125volt..
it is pulsing or not stable..
i already done voltage checking..
i see damage component the power supply transistor # 6N60FI and it is OPEN..
i also check all the components at the power supply its OK..
thanks for helping me sir dave...
Abs....
davenn
take a sharp well lit pic of both sides of the PSU board
6N60FI sounds like a power MOSFET will have to look for a datasheet
Yes it is ... the datasheet is here
cheers
Dave
davenn
OK on one filipino forum ... I had to get my wife to do some translating .... They were talking about a number of possible problems in the PSU that would cause the blinking red LED
1) .... 2 x 47uf/160v on the B+
2) .... R3523 = 390K
3) .... D6519 = BTZ03 -C15
4) .... and from what we caqn read there's a main regulator chip that periodically fails
and a couple of other reg's 7805 and 7808 possibly to check
Dave
