I've bought an old Philips PM3262, all is working, but I heard a noise and smell of ionized air in the rear.
I've opened it and the EHT is in dispersion, probably due to degraded isolation... it works as an ionizer on the edges toward the case; if I remove the eht from his home (so the case is not near) arches are formed only on the edges (they are visible only in the dark).
This EHT is made from the classic series of diodes / capacitors to raise the tension, completely drowned in the resin. The electric arcs are formed between the edges of the EHT and the case of oscilloscope (isolated by a plastic film).
I cleaned everything thoroughly degreasing (nitro solvent) and I've tried to increase the insulation with electrical tape, the noise and smell have decreased but are still present.
Someone has idea on how to increase the insulation so that there are no leaks?
Thanks,
Sebastian
Thanks,
Sebastian
