Philips 60" RPTV - New cooling fluid, clean lenses and mirror, still "cloudy"
This set has been focused (mechanically and electrically), all cooling
fluids replaced, lenses and mirror cleaned spotless, picture is still
overall hazy/cloudy. Possibly nature of this set? Model 9p6031c.
jakdedert
Hazy/cloudy compared to what? One thing you didn't mention cleaning was
the screen itself....
jak
Meat Plow
Did you clean the back of the screen?
Screen has been cleaned. Just for grins, I pulled the back off and
took a look at the crt's again. Lo-and-behold...blue is cloudy as is
the green crt. Coolant was replaced two weeks ago and was crystal
clear. Is it possible for bacteria to grow this fast already,
especially since the set hasn't been running much since? Another
thought is that MCM was out of coolant, so I had to get it from
tritronics. MCM has tech-spray and Tritronics carries MG Chemicals. I
topped off the crt's with the MG chems coolant. Is it possible the two
somehow reacted with eachother?
James Sweet
Did you scrub out and sterilize the coolant chambers before refilling?
The bacteria can grow pretty quickly once it gets started.
Meat Plow
Screen has been cleaned. Just for grins, I pulled the back off and took a
look at the crt's again. Lo-and-behold...blue is cloudy as is the green
crt. Coolant was replaced two weeks ago and was crystal clear. Is it
possible for bacteria to grow this fast already, especially since the set
hasn't been running much since? Another thought is that MCM was out of
coolant, so I had to get it from tritronics. MCM has tech-spray and
Tritronics carries MG Chemicals. I topped off the crt's with the MG chems
coolant. Is it possible the two somehow reacted with eachother?
I certainly wouldn't mix different brands of coolants. Better drain and
wait for your favorite brand to be restocked.
Meat Plow
Forgot to mention to clean the CRT chamber and lenses with denatured
alcohol then rinse with distilled water. Clean the orings with distilled
water because the alcohol will eat them. Seal the rings with 100% silicon
rubber. Use 100% cotton balls so you don't make scratches. This will
eliminate any uncertanties about a bacteria problem.
H
Homer J Simpson
How about diluted chlorine bleach?
Meat Plow
Fine if it doesn't react with any materials. I used everclear on mine and
drank what I didn't use :)
