Rodo
Hi all,
I bought this Philips plasma TV from Costco (Model# 42PF9431D/37). It is on
the wall in my bedroom. I noticed that it would click as if I turned it on
and after 10 seconds click again like if I turned it off when the TV is off.
This happens like once or twice a day. Because it has done it at night when
the room is completely dark, I can see the screen lights up a bit. It never
comes completely on when it is doing this. Otherwise the TV works fine, no
video or audio problems at all. After a few times of these I decided to take
it back to Costco and got another (same model no.). Guess what happened? ...
I got the same problem again :-(. So I decided to do some things to rule out
the power outlet:
I plugged it into an extension and into another outlet (away from my
bedroom). No change.
I plugged it into a UPS. No change
I cover the IR sensor in front of the TV. No change.
I finally called Philips and they referred me to a repair center. I just got
it back after they had it for two month. The receipt shows they changed
something called PSU and SSB. Here is the depressing part ... NO CHANGE!.
I called my credit card company and I can do something with them to return
it but I really like the TV. Other than this click on, 10 secs later click
off, it really is a nice set. Not to mention that the installation is
already done on the wall. Anyway ...Can anyone suggest what else I can check
in my place that may be causing this TV to do this ?
Thanks a bunch everyone... comments/suggestions welcome.
the power outlet:
