Philips 41JP20 dead
James Sweet
Still have this Philips 41JP20 awaiting my attention, replaced the BUW12A
and HOT but the power supply still doesn't fire up, just makes a faint buzz
then the relay clicks again and the orange and red LED's come on too.
Standby voltage is there, not even a peep out of the other outputs. Any
insight as to why the power supply isn't starting up? I thought I checked
all the semi's but maybe I missed something.
Jason D.
What about resistors, caps? This can stop the whole show.
Also philips used neon blue caps, they go bad.
I'm not famillar with this philips chassis, what kind of this SMPS
topology? One for standby only, one for main run power? Or same SMPS
for both standby & run? Or uses regular standby transformer to power
micro in turn trips the SMPS to run when commanded to turn on?
Cheers,
Wizard
James Sweet
Cheers,
Wizard
I thought I checked all the lytics for ESR, replaced a few that were
questionable. It uses a normal 60 hz transformer to provide the standby
voltage.
Bill Jr
James,
Look for a 100uf 200 volt lytic near the relay and replace it.
Also look for a 300k and 330 k resistor pair in series near the middle of
the board.
You could also be facing a bad flyback.
Good Luck,
Bill Jr
BWL
I have also seen a bad zener diode cause this; can't remember the location # at
the moment; it's located in the "do not service" area of the P.S.
Jason D.
voltage.
Better do that and see what you find by others whom suggested other
things to check.
Okay, A trick I use often because I've wearing hearing aids and can't
hear flyback whistle or chirps of a SMPS so I used an scope probe
laying along the core of the flyback or SMPS transformer core.
This will instantly tell if your dog is trying to start SMPS part.
This is unlike the recent JVC CRT TVs power topography, that one that
states 105W, uses regular transformer for standby, very efficient SMPS
& degaussing is juiced by the relay.
Cheers,
Wizard (deaf guy but can hear things generally with hearing aids but
not all of freq ranges.)
Similar threads
Replies
0
Views
894
James Sweet
Replies
5
Views
1K
James Sweet
Replies
4
Views
1K
James Sweet
Replies
5
Views
1K
John Del
Replies
4
Views
1K
James Sweet
