Chris
Hello!
I have an old Philips 27CE3590 set which has some (probably age
related) problems. Since you guys have been extremely helpful in the
past, I thought I might try to ask here to see if anyone has any tips
to share.
Problem 1:
About four years ago the HVPS broke down, which turned out to be a
fried fuse resistor. The symtomps then was no picture, but everything
else worked fine except for a loud pop from the speaker when the set
was put into standby. After replacing the resistor, the problems went
away.
However, after a few years, the loud popping came back. Sometimes,
there is also a second pop after the set has been in standby for an
hour or so. Rather annoying... Seems like there is some kind of
power-off discharge circuit that has stopped working properly?
Problem 2:
Probably a FAQ item, but I poked around a bit and didn't find anything
about it. The problem is a high frequency wiggling ("buzz") in the
picture. This has grown worse over the years, but has now reached a
point where it's becoming quite unacceptable. Looks like some kind of
problem with the horizontal sync. I've been told that the likely cause
is a worn-out capacitor, but what should I try to replace?
I'd be grateful for any hints!
Cheers
Chris
to share.
Problem 1:
away.
Problem 2:
Cheers
Chris
