Ok, this is exactly what i did. However, it's debated where
exactly, is the cutoff frequency between the carrier and the noise.
Hello Paul,
I assumed you did measurements with a spectrum analyzer (just scalar
measurements, no vector based stuff). For determining "delta phi" you
need a vector analyzer (or at least a quadrature down conversion
setup).
You might change the RBW setting and look how the spectrum changes.
Below a certain RBW setting, it will not change. In that case the
skirts can be because of the signal's phase/frequency noise, or phase/
frequency noise from the analyzer.
When you have a known stable source, you might be able the measure the
frequency/phase noise contribution from the analyzer. An indication of
the analyzer's noise is the response at zero Hz.
I don't know your application, but noise very close to the carrier
might be suppressed by your application (digital frequency tracking
loop or just block length of the digital demodulation process?). Is
it possible for you to derive the CNR from the output at some stage
in you digital processing? Of course in that case the receiver front-
end must be good.
Best regards,
Wim
PA3DJS
www.tetech.nl
The real address is the one without a, b and c.
