Phase noise analysis in cadence - Convergence issues
srini
I am working on phase noise simulations of pll blocks at transistor
level at 2.4ghz in
tsmc18rf with spectre simulator using cadence.
For clock divider, the pss(periodic steady state) analysis does not
converge. it stops after 20 (or max period) iterations. also, jitter
and phase noise analysis for phase frequency detector also does not
converge. it takes long time to run and then finally reports
convergence problems.
i tried following the suggestions given in cadence documentation and n
the output log, but to no avail.
how to set the different parameters tolerances for
reltol,abstol,maxsteps,ltration,steadystate ratio. i tried loosening
some of them, still it did not yield results.
I tried the following settings"
for pss:
fundmental tone is 2.4ghz large signal input
beat period: 0.41666n or 0.83333n (tried both)
no. of harmonics: 20
accuracy settings: conservative, tsatb =800n
i have not highlighed oscillator as this is a driven circuit.
in options, maxstep is 10ps. steadyratio=1, integration method: method
is gear2only and tsabmethod =gear2only, highorder=yes,
psratio=1,maxorder=12.
for pnoise analysis,
sweep type=relative, relative harmonic=1 or 100k,
freq range = 1k to 100M
sweep type = logarithmic, points per decade =5
max. sidebands = 10 or 20(tried both)
output = voltage
input = none,
options: gear_order=3
am i making any mistake in the above settings/analysis?
is there any documentation or info on this....any suggestions are
highly welcome.
thanks
srini
