Phase lock loop questions.... Really in dilemma
Hi everybody
How are you doing today!
I have several questions related to Phase lock loop. I already
implemented a layout for a charge pump phase lock loop. It is working
fine. I really want to do the process variation on it for my master
thesis and however I am stuck now....
The first question is how to get the simulation result on DC gain. I
know how to calculate the DC gain with analytical results (get the
transfer function and make the s = 0). What I want to do is to vary a
capacitor or resistor's value and get the experimental results on DC
gain using Hspice and see if the DC gain is changing in the direction
predicted by the analytical results. However, I do not know what to
measure to get the DC gain with hspice. I mean I do not know what value
I should measure to get the DC gain. I tried to give a DC reference
signal, but that does not seem right.
The second thing is that I want to find some analytical results giving
the relationship between the any transistor sizing and the any loop
characteristics. For example, the charge pump's currency is related
to the transistor size. I think the currency is also related to the
loop's locking time, locking range, etc. If I can get some analytical
results on that, that will be very wonderful! Of course, the loop
characteristic has to be some thing that I can measure from hspice
simulation results.
Now I just have the equation for the first order xor pll from my text
book. That is a super simple topology and even does not have charge
pump. I cannot use that since it is not the same as my topology and the
topology is too simple - my advisor said.
Could any body give me some hints on the analytical results of this
type for a traditional phase lock loop? Any reference or any ideas?
Thank a lot a lot if anybody can help me out.
My email address is [email protected]. If you have some
ideas and you do not mind sharing your ideas with me, kindly please
drop me a line. If you are in US too and you prefer talking directly,
please leave me a number or I can give you my number.
Thank you very much again!
Have a nice day!
Jim Thompson
Hi everybody
[snip]
Have a nice day!
Sounds like you don't know enough about phase-locked loops to even
consider doing a masters thesis.
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice:(480)460-2350 | |
| E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
| http://www.analog-innovations.com | 1962 |
Make Cinco de Mayo a Day Without a Gringo
Abstract Dissonance
Jim Thompson said:
Hi everybody
[snip]
Have a nice day!
Sure he does... Only thing you need to know to do master thesis in these
days it what a thesis is... then you can just get everyone else to do the
work for you. i.e, its there to measure your competence in getting everyone
else to do the work for you. (similar to how HW is these days)
I hope you really don't think that college is there to measure and increase
intelligence? I think I came out stupider after my "incarceration"(and broke
too).
Tim Wescott
Hi everybody
Once you define what you mean by "DC gain" the nature of your test will
be clear. Review the assumptions you made when you threw out all of the
inherent nonlinearities in your PLL to make a transfer function, and see
what "DC gain" means.
I think your best bet to find loop characteristics would be to make a
step change in the input frequency (or the commanded frequency if its a
synthesizer) and look at the evolution of the output frequency as it
settles to its new value. You'll probably have to export the results to
a text file and do the frequency measurement in MatLab, or simulate a
discriminator circuit with ideal components (and verify it's correctness).
simulation results.
Think of a voltage-output phase detector driving an op-amp integrator.
Now think of the action of a switched constant current source driving a
capacitor. See any similarities?
You _really_ need to read a good book on phase locked loops, or take a
class if you can. "Phase Locked Loop Circuit Design" by Dan Wolaver,
Prentice-Hall 1991 will work. Floyd Gardner's book is more widely
known, it's probably more widely available, and it probably has the
information you need.
Plan on not getting very many direct responses. Newsgroup respondents
usually like to respond to the group, in public, for the benefit of all.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
"Applied Control Theory for Embedded Systems" came out in April.
See details at http://www.wescottdesign.com/actfes/actfes.html
Jim Thompson
Jim Thompson said:
Hi everybody
[snip]
Have a nice day!
too).
Ah!! "Ignorance makes right"??
...Jim Thompson
Mark
Along the lines of what Tim was saying...
also think about the relationship between frequency and phase....
your control loop is using a PHASE detector...
and a VCO is a FREQUENCY controlled device...
what does that mean in terms of the nature of the DC GAIN?
Mark
Jim Thompson
Mark
Bwahahahahaha!
...Jim Thompson
