pcb: the opensource program and merging two files
samiam
Just wondered if anyone did something like this
I have two pcb layouts done with the opensource pcb program
layout 1 is for the top board
layout two is for the bottom board
both boards are 8x5
I have decided instead of merge them into one board of size 8x10, and I
thought that simply doing the following
opening top.pcb and increasing it to 8x10
opening bottom.pcb and increasing it to 8x10 and moving the layout to
the bottom of the 8x10 window
cat top.pcb bottom.pcb >newlayout.pcb
editing the newlayout.pcb to make certain theres one header and non
duplicate parts
But that hasnt worked out
anyone ever had to do something like this?
If all fails Ill just redo the layout on an 8x10 sized board, but it
would cost a week - which is probably the best thing to do in the long
run anyway :)
DJ Delorie
You want the "load layout data to paste-buffer" option, you can't just
concatenate them. The load layout option lets you paste one board
onto another.
Or you can use my panelizing scripts:
http://www.gedasymbols.org/user/dj_delorie/
pcb2panel lets you rearrange the outlines, panel2pcb merges them
according to the outline layout.
Peter Bennett
both boards are 8x5
duplicate parts
run anyway :)
In Protel, I'd copy-and-paste within the PCB editor. I'd open the two
original PCBs, and a new one, then copy PCB1 into the new PCB, and
also copy PCB2 into the new one, positioned so it doesn't overlap
PCB1.
I can't see that simply concatenating the two PCB files using a
Linux(?) command will do anything useful.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
samiam
onto another.
Much appreciated!
