I can make printed circuit board easily. But I'm having a hard time trying find a way to make them last longer and protect them from oxidation and corrosion. I have to make a lot of these boards and each board requires a bunch of soldering. Want do my best to make them last.
I gave a UV solder mask paint a try, but it was really hard to put on evenly across my large boards,and over all they just didn't look good. So I had to look into some other options. I found this Conformal Coating that you could spray on. But after a week, my copper started to tarnish in small areas across my circuit board. I put three coats on, allowed each one to fully dry before applying the next one, but it didn't work out for me. I feel like there is more out there that could fix my problem.
I saw this stuff a few days ago called liquid tin. But I couldn't find much information about it other than its used to tin the copper. I didn't want to buy it until I was sure it could be used for my needs. What do you all think I should do?
MG Chemicals Acrylic Lacquer Conformal Coating, 340g (12 Oz) Aerosol Can, Clear
Link to https://www.amazon.com/gp/product/B008OA7178/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
My PCBs are 2" x 9" They only hold LEDs and Resistors
120 5mm LEDs and 40 1/2w Resistors
need to make 12 to 16 of these boards
