Jamie Morken
I am trying to decide the best fuses to use for a battery inverter with
a max voltage of 60VDC and max operating current of 75Amps. The
operating current is limited to 75Amps by the power supply, so the fuse
is just a backup, so I was thinking setting the fuse to 80Amps or even a
bit higher. The 60VDC is higher than most fuses seem to allow, due to
arcing, but there are some 5mm x 20mm ceramic fuses that are rated
16Amps at 125VDC:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=0001.2516-ND
and some 5mm diameter beryllium copper fuse holders:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=283-2827-ND
Would putting 5 of these fuses in parallel work well with a continuous
max operating current of 75Amps?
Also I was thinking of some 3AG fuses (1/4" or 6.35mm diameter), the
glass fuses in this size are rated only to 32VDC, but there are also
some ceramic rated at 30Amps and 125VDC. So three of these in parallel
could work as well.
3AG fuse:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=F2655-ND
3AG(1/4") fuse holders:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=F046-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=283-2342-ND
Are there any other cheaper ways to fuse 60VDC/75Amps on a PCB that can
meet UL standards? I was thinking of using ATO/ATC series automotive
blade style fuses, but these seem to mainly be rated to only 32VDC.
ATC series 30Amp/32VDC fuse:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=283-2322-ND
ATC series fuseholders:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=3522K-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=3522-2K-ND
I'd like to just pop in 3 of those ATC series fuses, but I don't know if
its really that safe at 60VDC. (might make an arc welder?) Are there
any other higher volt rated blade fuses in these sizes?
cheers,
Jamie
16Amps at 125VDC:
could work as well.
3AG fuse:
cheers,
Jamie
