Hi Everyone,
I am working on creating a PCB footprint based on the dimensions from the datasheet for the connector I'm using. I'm a bit confused about whether I should design the footprint using the dimensions shown in mm or the dimensions shown in inches? Which would be better to use? Is there a way to tell if the manufacturer designed the footprint using mm or inches as their unit of measure? I attached an image from the datasheet of the PCB footprint for the connector to this message.
Thanks for your help!
Dan
Dan
