PCB Edge Connector
Can anyone please help me to identify this connector and please give advice as to where I can purchase from. It is 6 way with 5mm between each tang. The board is normal size (2mm (ish) thick).
I think you'll find it's 5.08mm between connectors, and the board is probably 1.6mm thick :)
That spacing is very common among larger or higher voltage connectors. It is 1/5 of an inch spacing, or double the 1/10 inch (2.54mm) spacing that is common in electronics.
I can't see enough detail to make an exact ID.
I looked up "card edge connector" on mouser and they have lots (although none that match your exact requirements).
Here is a datasheet which may help you determine the parameters you need to search for.
