PCB design problem
Greetings!
I am building a small amplifier to use in a portable speaker build that I'm doing.
It's based on LA4192 chip.
The problem is when i tried to design the board in the Target 3001 or Eagle. I can't find the LA4192 chip.
Is there an IC with the same layout that I can use instead?
Here are the pictures I have:
Any other solutions are welcome.
Thanks!
Use a more modern design/chip.
Where specific device designs don't exist for the software you are using it is normal practise to create your own using the software parts creation tools - assuming yours incorporates such (most modern programs do).
You could just place a 16-pin DIP device and edit the middle pins to incorporate a slot.
I could use a more modern chip but i like this one and I already purchased the parts. I will try to create/edit my own. thanks
