Nicholas Kinar
Hello--
I'm currently selecting resistors for the feedback loops of a few op-
amps and in-amps used in the analog front-end of an 18-bit SAR ADC. The
ADC reference is 5V, so the smallest theoretical voltage (with 0V to 5V
input range) that can be resolved is 5V/(2^18) = 1.9E-5 volts.
Page 719 of the the "Data Conversion Handbook" edited by Walt Kester
gives an excellent overview of how resistor temperature coefficients can
affect ADC errors. According to an analysis given in this book,
resistors with a TC of 25 ppm/degC can be unsuitable for a 16-bit system.
Now it would be possible to eliminate some error by using a resistor
network with closely matched resistors. I would like my circuit to
maintain 18-bit accuracy over a temperature range from -40 deg C to 10
deg C, which is a 50 degree range. Since the resistors are matched, the
values will change in a similar fashion over temperature.
I think that I might have to use extremely high accuracy parts (which
are also extremely expensive), but I am hoping that there would be some
other way to maintain accuracy.
Could anyone recommend a manufacturer or source of resistors and
capacitors which could be used in an 18-bit system? Vishay is the first
company that comes to mind, but which series of components should be
used?
used?
