Hello,
I have a microcontroller which is connected via a connector to signals from another PCB.
The header used is the following one......
http://www.molex.com/molex/products/datasheet.jsp?part=active/0022112062_PCB_HEADERS.xml
......the microcontroller input , as you know, draws no current, as its an input...so therefore no current is passing through this header (connector).
I believe that there are minimum current levels for metal to metal connectors?
Since my connection passes no current, will it be OK?....(the connection surface is made of gold)
