Hello everybody,
I'm new to the forum which I come across looking for a fix for a technika TV I was given. I wonder if anyone can help identify the problem, or give a pointer on what to try to find a fix. Unfortunately though, I have pretty limited equipment to work with (a DMM, soldering iron and a magnifying eyepiece!)
The model number is LCD19DVDID-107.
The fault is that there is no DTV reception, and the DVD doesn't work. The TV operates as it should with a Scart input.
The symptoms of the faults are:
with DTV selected, the screen shows white, with the green DTV ident in the corner, then the "no signal" banner is displayed. This happens when a know good aerial signal is connected;
with DVD selected, the screen shows white, with no ident, and no functionality from the dvd drive.
I have tried the following so far. A visual inspection of the motherboard, PSU and what I take to be the DTV tuner board. I noticed a few bulging electrolytics, which I replaced, one on the DTV board, 3 on the PSU. I noticed a few pathces of flux which I cleaned up. There looks like a bit of bleeding/leakage from two low profile transformers on the PSU ( I guess these are for the screen which is functioning correctly) I reflowed some joints on the DTV card (pins from the tuner module), and on the PSU just to clean up a bit. I measured 12v supply to the DTV board on the red/black 2 pin connector. I didn't know which pins carry power to the DVD drive, but I did measure 12v on at least one of the pins on the ribbon cable. The faults were the same after the above actions.
After that I'm at a bit of a loss. I would be very grateful if anyone has any ideas on how to identify/fix the problems, any help would be much appreciated. Of course I realise this is a low value item, so a repair would need to be econimical, but it would be a shame to junk it at this time.
Sorry for the rather long post,
Mark
Mark
