Jamie M
Based on the recently reported linear particle "accelerator on a chip":
http://news.stanford.edu/news/2013/september/slac-chip-accelerator-092713.html
http://arxiv.org/abs/1308.0464
http://phys.org/news/2013-09-chip.html
http://phys.org/news/2013-10-particles-compact-particle.html
I was thinking about how this could be turned into a circular particle
accelerator instead of a linear accelerator. The linear version seems
to use a glass (or other transparent insulator) with small cogs in it
proportional to the accelerating radiation frequency, so for making a
circular accelerator, it would require this to be a circular gear type
shape, like a change shown in this image from a linear gear to a
circular gear:
http://en.wikipedia.org/wiki/File:Pitches.jpg
For the material used I was thinking a scintillator crystal could be
used that is energized from the center point of the "gear axle" so that
all "teeth" that accelerate the particles will be in phase. There are
other ways to do this, ie with multiple fiber lasers going to gear teeth
sections too.
http://en.wikipedia.org/wiki/Scintillator
Now the electrons will be accelerating, but the problem is they will
want to travel in a straight line, so the gear needs some holding force
to keep them in a circular motion!! At first I was thinking maybe an
adjustable DC bias voltage could be used to hold the particle beam while
it is rotating, but depending on the feedback for the voltage I'm not
sure if this would work?
A simpler new idea I had was to use a different gear tooth design that
automatically will hold the particle beam while it travels around the
circular gear.
This type of herringbone gear design could provide an axial holding
force on the particle beam:
http://en.wikipedia.org/wiki/Herringbone_gear
http://en.wikipedia.org/wiki/File:H...,_Sketches_of_Engine_and_Machine_Details).jpg
This other design of herringbone could provide a radial holding force on
the particle beam:
http://en.wikipedia.org/wiki/File:H..._patent_(Autocar_Handbook,_Ninth_edition).jpg
And for a combined axial+radial holding force on the particle beam, it
is possible to "bend" the already triangular herringbone shape into a
compound triangle shape so that there is radial and axial holding force.
Now when the gear teeth are energized by a laser and the electric field
on them should be able to accelerate the particles and also hold the
particle beam in a focused circular beam at the same time I think!
cheers,
Jamie
circular gear:
sections too.
circular gear.
the particle beam:
cheers,
Jamie
