Hello Guys,
Please i need some little help and suggestions. the idea is to control a DC normal motor in both 2 directions using Parallel port.
I managed to get this working the schematic is attached. The batteries V1 and V3 are where 2 PINs from parallel port are supposed to be connected ( was just testing using the simulator) . The parallel port output is about 2V .
The problem is even if i measure the output voltage to the motor which it's about +/-5V , the turn force of the motor is not the same as if i supply it directly with 5V . i was wondering what cause this but can't figure it out . Please if someone have any suggestion that will be great.
