Pioneer VSX-453 Repair
I have a pioneer VSX-453 amplifier I'm working on for a friend. The amp left channel has a lot of static at lower frequencies, while the right channel is fine. I pulled it apart and hooked my scope up to it with it playing a 70 hz sinewave, and found that for the left channel, the waveform is fine up to the power amp, and past the power amp, the top of the waveform is 'chopped off', see below:
For that image, the upper channel is connected to the left channel input to the power amp board, and the lower channel is connected to the left channel output from the power amp.
This is a Class AB push pull amp, that uses a 2SA1302/2SC3281 PNP/NPN pair. Measuring the output of each transistor with the scope yields the following results:
PNP (2SA1302): The output waveform is the same as the lower channel in the image above.
NPN (2SC3281): The output waveform is a very shallow almost sawtooth looking wave.
To me it looks like the NPN output transistor on the left channel is bad, is this a fair assessment or do you guys think something else may be to blame?
