Meat Plow
Screw Panasonic parts research. Called them three times
and they won't call back. Anyone replaced these associated
with the green convergence?
R7048, 49, 50, 51 ? (near the four wire plug going to the green crt)
They've all had the paint burned off but measure 98.5 ohms each.
Something I've worked on in the past but I can't recall what says these
should be 10 ohms?
Only problem with the set is the green convergence is off by an inch or so
so I thought I'd replace the STK devices and of course the resistors that
were hot.
should be 10 ohms?
were hot.
