G.M. Durrence said:
Checked all that, also checked all ribbon cable connectors. Even the
menu doesn't have green so this eliminates cables and connectors. I
also made sure the CRT was socketed well. I suspect an internal CRT
problem but would like to test voltages on the CRT before discarding
it I but need a schematic.
You don't need a schematic for that. You have three identical video circuits
so comparing voltages, preferably with a grayscale or white display on the
screen at the time, should be straightforward enough. If the green channel
measurements differ significantly from the others, chances are there's a bad
component on the CRT base PCB, ie video amp IC, open resistor, bad driver
transistor etc. It could also be a cracked solder joint, particularly on the
CRT socket. If the R, G and B cathode pins on the CRT are all giving similar
readings, then the green gun on the CRT has probably failed
catastrophically- it happens sometimes.
There's freeware pattern generators on the web which will display
appropriate patterns to help you.
Dave
