Platforms
Content
Don't know where to find them. I have never been inside one of these.Hi Steve,
Have you checked the obvious fuses?
Martin
If you take the top off, you will see where the mains power comes in. There will be a fuse close to it.Don't know where to find them. I have never been inside one of these.
Yes I have a multimeter but only no how to test voltage with it. I learned this while making numerous different types of capacitors. My first learning experiment.lolIf you take the top off, you will see where the mains power comes in. There will be a fuse close to it.
Or on the back a fuse holder (circular) black item.
And of course, do not take the top off without unplugging the unit.
Have you got a multimeter? If not it's a very necessary first tool.
Keep us posted.
Martin
Please don't laugh... what will bad capacitors look like, how do I check for continuity?Safely not really.
You can do a visual check of capacitors on the power supply for leakage or bulging.
Have you checked the mains cable for continuity?
Otherwise the unit will need to be plugged in and test for voltages on the primary side first.
Martin
let me see if I can find a photoPlease don't laugh... what will bad capacitors look like, how do I check for continuity?
Ok, got images and get the pic. Lol also I have the setting on meter, but how do I check the continuity and where?Sorry my image is too big.
Search for bad capacitors and view them from images.
You will get the idea.
Continuity is probably on your meters 1 o'clock symbol.
Put dial there and touch the two probes together. It should give an audible beep.
Martin
So no beep means it's bad, does this work with all componants, which ones would cause no power at allDoes it beep when you touch probes together?
Testing continuity of fuses, wires etc will beep when you probe both ends of a wire or fuse.
eg: get a length of wire or a fuse and put a probe from the meter to each side. It should beep. that would normally show the fuse is good etc.
Martin
Yes I get a beep, and the screen says open if the leads r not touching. When I plug the unit in and press power, nothing happensYou have not confirmed that you get a beep yet!!
No it doesn't work with all components.
Causes of no power is very wide.
You don't know whether you have power yet.
Martin
The theater system is the unit I meanYes I get a beep, and the screen says open if the leads r not touching. When I plug the unit in and press power, nothing happens
I am just reading the service manual.
CAUTION, don't go probing around!!!
Unplug it and first check for continuity on the mains cables.
I am not comfortable with this BTW.
Are you competent in checking voltages?
Martin
