Active8
Hi:
Two examples here. One in LT Spice and one in another CAD, I'm not
sure which.
Field Strength Meter.gif by analog
It uses a parameter called "Rser" for the meter inductor, V1, and
the batts. and "Cpar" and "Rpar" for L1 and L2.
I see those parameters are part of LT Spice's part properties.
Impressive. I bet that means that SS has those, too.
but then there's the
High side firing circuit.jpg from a disscussion under various
subject lines including "High side firing circuit".
It has a line "C1 = 0.014 ESR" which may be just text. If that's a
PSpice program then the braces are missing and there's no .param
line on the schem.
I can put a parameter in PSpice and/or a special part property for
ESR and stuff like that, but how do I get it to actually count? A
cap's a cap in PSpice AFAIK and I've been just adding coil
resistances and such as separate parts.
Is there a way to make a param like that count in PSpice, or do I
have to define a subcircuit for a symbol and pass the param to the
parasitic while dealing with whichever schem capture app I'm using?
Something tells me that's what really happens in LT Spice - a
subcircuit, but the param is called a symbol attribute or SYMATTR.
sure which.
line on the schem.
