Hi
I am trying to fault find a problem with an amplifier/mixer that was instantly blowing fuses when powered up.
The unit is the IMG Stageline PX-400
I managed to obtain some schematics and found that one of the main output transistors (TR217 MJ15004) on the audio left side of the amp was was short circuit.
I have replaced the output transistor along with the bias transistor (TR216 2SB1186A) however when testing the resistance across the base and emitter of the output transistors I am seeing some variance in readings.
I have attached a schematic of the left side of the audio amp circuit in question and was wondering whether someone could tell me what sort of resistance I could expect between the two points detailed on the schematic.
The resistance I am seeing across the two points (detailed in red) is 12.3 ohms, which I believe is a summing of the two resistors (R236 and R238). However when I test resistances across the other output transistors across base and emitter I am seeing 10.1 ohms (detailed in green)
On the audio right hand side of the amp I am seeing resistances of 10.1 ohms across both output transistors.
As I say would be grateful if someone could take a quick peep and let me know what resistances I should be expecting at these two points.
To me it seems as though 12.3 ohms is the value I should be expecting but seems strange that R238 and R237 could be short circuited on both left and right sides of the amp
Thanks in advance
Look forward to hearing your views
Thanks in advance
