OT Skype phone number popup whinge
F
fritz
After installing Skype for videocalls I have noticed an annoying problem.
When I view a webpage with numbers in a list - e.g. a train or bus
timetable or an electronics catalogue with order numbers - I often get
a Skype popup which thinks the combination of numbers is a real phone
number and a hotlink to dial them via Skype appears. This might be OK if
they really
were phone numbers, but almost always they are NOT phone numbers,
they are just bus times or catalogue numbers that the stupid Skype software
decides ARE phone numbers.
Anyone else had this specific problem ?
I have exhausted all 'HELP' options within Skype to try and fix this.
I don't want to disable ALL popups just for this one Skype pain-in-the-arse,
nor
do I want to disable ALL 3rd party internet extensions.
And BTW I have removed Skype from the Start Menu with MSCONFIG, and the
problem occurs even though I haven't run Skype after starting the PC.
Helpful advice welcome.
Don McKenzie
they really
nor
tools > options > Advance Settings > Callto: links enable/disable
is that set off?
Cheers Don...
Don McKenzie
Site Map: http://www.dontronics.com/sitemap
E-Mail Contact Page: http://www.dontronics.com/email
Web Camera Page: http://www.dontronics.com/webcam
No More Damn Spam: http://www.dontronics.com/spam
Product Sellout: 15% OFF 4DSystems OLED Displays & modules.
http://www.dontronics-shop.com/micro-oled.html
F
fritz
is that set off?
Cheers Don...
The option you suggested under Skype>tools >options>Advance Settings>Callto:
links enable/disable is disabled.
Yet the popups still appear, even though that option is disabled.
The only way I have found to stop the Skype popups is to disable under
IE8>Tools>
Internet Options>Advanced>enable third-party browser extensions
This fixes the Skype problem, but stops up all other third-party software as
well.
Thanks for the suggestion anyway!
Fritz
Don McKenzie
IE8>Tools>
well.
Fritz
I don't have this problem, but then I'm not running IE.
Try section isolation.
Have you tried another browser such as Firefox?
Even if you don't want to use firefox, and least it will tell you if it
is IE related, and not a skype bug of some sort.
Cheers Don...
Don McKenzie
F
fritz
Even if you don't want to use firefox, and least it will tell you if it is
Cheers Don...
That would be a last resort, I have emailed Skype detailing the problem and
I expect them to fix it without requiring a change in my browser choice.
If Skype does not respond to my modest request, so be it.
I expect Skype.com to explain why their software is doing what it does
within IE8,
while I have never selected it, inserting stupid pop-ups during bus
timetables.
L
Larry
they really
software
pain-in-the-arse, nor
Have you looked in Tools - Manage Add ons in IE. If there is an add-on
causing this, just disable it.
Larry
F
fritz
Larry
Thanks, that seems to have worked. I disabled anything to do with Skype, and
with 3rd party extensions enabled I don't get the silly Skype pop-ups in
websites with numbers (like timetables) anymore.
I just wish the bastards wouldn't make all that crap the default state when
you install Skype.
BTW
Is Skype really the best free software for video calls ?
Fritz
F
fritz
Larry
Since I last posted I have received an email from Skype ......so they do
respond to problems...
<quote from Skype email>
Thank you for contacting Skype Support.
We are sorry to hear that you are having problems with the Skype plugin.
We understand you would like to remove the number highlighting feature
in Skype.
To disable number highlighting please follow these steps:
1. Open your web browser
2. On the toolbar you should see the Skype Add-on/extension icon
3. Click on the icon to turn it off.
If you are not able to find an add-on/extension icon, then reinstall
Skype as follows:
1. Uninstall Skype from:
Start > Settings > Control Panel > "Add or Remove Programs" (for Vista
users, Start > Settings > Control Panel > "Programs and Features").
2. Search for "Skype" and remove/uninstall it.
3. Download Skype from http://www.skype.com/go/download
Important: Once you start the installation process, click on Options,
and make sure the following check box(es) are unticked:
- Install Skype extension for Mozilla Firefox
- Install Skype add-on for Internet Explorer
And proceed with the installation as usually.
Please do not hesitate to contact us again if you are experiencing
difficulties.
Don McKenzie
Skype as follows:
--- snip
difficulties.
and a good answer also by the look of it.
Cheers Don...
Don McKenzie
F
fritz
Don McKenzie said:
--- snip
Cheers Don...
I am impressed that a free service like Skype provides such help, and
quickly too.
I can only recommend others to try it - I use it for international
videocalls and apart
from the (now resolved) problem with popups, it works very well indeed.
Similar threads
Replies
30
Views
3K
Jasen Betts
Replies
2
Views
1K
Don McKenzie
Replies
4
Views
1K
Dirk Bruere at NeoPax
