I haven't done this in years, so could I have everyone's opinion for
best hard drive cloning software?
I have one that's starting to exhibit clunking noises and I'd like to
copy it *now* so that I don't have to do massive software re-installs
...Jim Thompson
Norton Ghost works well for this, although I haven't used it in a few
years.
Another approach is to do a full backup of your system (this can be done
over the network, if you are part of a LAN), making sure you backup the
system state as well as all of your files. The system state is a special
checkbox you have to check during the file selection phase of the backup
process.
Then, you would have to install a new disk, re-install Windows, since the
backup and restore software only runs under windows, (but you can do a
bare minimum installation) then do a restore of the full backup. When you
reboot, your system will be just like it was at the time of the backup.
It's a bit of a pain, but it has the advantage of not needing any other
software and working easily over a network.
I have done this with win2k. winXP uses the same backup software, so it
should work there, too. I'm pretty sure windows 95 and 98 had similar
backup programs.
Mac
