Platforms
Content
A 5-inch gun shoots a projectile weighing about 70 lbs, with about 18MooseFET said:From the look of the sparks, the gun is eroding its self. Some of
them look like iron sparks but the object appeared to be aluminum.
They also have a problem with the projectile trying to rotate in the
gun. I would not want to be anywhere near the gun when they try to
ramp the power up.
I wonder if it really is 10MJ or if that is just the offical line.
Back in WW2 all ships could do 23 Knots if you asked how fast a ship
could go.
ramp the power up.
could go.
Martin Riddle said:
That's little low.
Many warships would easily do much better, years before the outbreak of
hostilities.
What program did you use to play the video?
MooseFET said:23 Knots was the story you'd get if you asked. It was a number that
sounded good and news reporters even back then weren't technical
enough to know that it was just a story.
While they fire one projectile at a cost of millions, the dastardly
enemy opens fire with a cheap and reliable Gatling gun and rains down
thousands of projectiles.
Which...harmlessly plink off the hull. Try again.
Again, cheap, proven, reliable technology that you can pump out by theNow, a sixteen inch Iowa class naval gun, that's something to think
about...
Really? An Avenger "tank buster" will fire shells that bounce off the
hull?
http://en.wikipedia.org/wiki/GAU-8_Avenger
hundreds and fire hundreds of times.
Each projectile provides its own power, "densified" at the explosives
plant.
If the rail gun fails, you can't fire any projectiles anymore.
This argument is NOT about weapon systems. Its about politics.Jim said:[email protected] wrote in [email protected]:
which could not get NEAR a warship,as SAMs and AA Artillery(AAA) would
obliterate them. Those Gatlings only have a limited range,WELL inside a
ship's defensive screen.Phalanx or Goalkeeper would tear the A-10s apart,if
the SAMs didn't.
(and that also neglects comabt air patrols the enemy would have to fight
through.An A-10 could NOT fight thru.)
Also,the GAU-8 had the A-10 BUILT around it,and it's a old,SLOW
aircraft,very vulnerable to todays air defenses.
There are NO other planes that carry the GAU-8.
None that could carry it,AFAIK.
nobody knows how to use those 16" guns anymore,the projectiles/powder are
old and scrapped(along with the entire Iowa class BBs)
In fact,no US ship today carries any gun larger than 5".
A 155mm gun(6") is being considered for a new type of ship.
No 16" naval gun could be fitted on today's warships.
rail guns will have a much greater effective range.
100's of miles vs ~3/4 mile.
they also may fire terminally-guided projectiles.(at Mach5)
Big clue;it's not just the guns/weapons,it's the entire SYSTEM that
matters,AC or warship.
about...
Is this the one?What program did you use to play the video?
lbs of HE. At 10 MJ, the muzzle velocity is just over 800 m/s, which
isn't so far off from a normal artillery muzzle velocity. If they can
really reach 32 MJ, that would be a beast.
Cheers,
Phil Hobbs
Jim Yanik
jyanik
at
kua.net
But Courant had already worked out the determination of top speed
capability of warships using bow wake angles at a known speed as
collected from aerial reconnaissance photography...
"Because the railgun uses electricity and not gunpowder to fire
projectiles, it eliminates the possibility of explosions on ships."
What do they use for power, then, that can match gunpowder? Middle of
a battle: "Captain, batteries are running low again. Time to
requisition the crew's Energizers?"
