Can an oscilloscope be used to test the value of an air-wound single-layer inductor coil?
Or, for that matter, any devices' inductance?
My DMM 'L' range's lowest is 2nH, so reasonably accurate down to about 0.2nH.
Meter blew recently, anyway (wrong scale and probe-sockets - 220V RMS 50Hz AC while still on 'L' range).
..%ph#u@%^)^!! said he.
However, as scope cap-test (above post) seems more accurate than DMM at smaller values,
i'm hoping that it can do the same service to my 'Coiled Creations'.
Plan to test in the region of 5nH>0.1nH with high accuracy requirement.
I have a home-built (kit) of a frequency/waveform generator 0Hz-1MHz at 0-10Vpp producing SIN/SQR/SAW.
Could this be used to 'resonate' the coil, then scope measures.. erm.. peak?
My plan is to design/test/build RF filters, wavetraps, antennas in the VHF (AM) range of 110-150MHz.
Way above 1MHz, so my train of thought is this:
As feedback cap input+<>output+ with grounds hooked together forms an oscillator at res. freq of cap,
and sine voltage about 10 V pp, the oscillator could 'drive' the coil at higher frequency.
Then where to from here?
Fairly new to scope, so full capabilities of testing not yet learnt. ^^
