Oscilloscope Help
What is it you are measuring on the scope?
The remote will likely draw uAmps when no button is pressed.
Bob
Thats exactly what I'm trying to measure.. uA's.
I measured a current draw of less than 1.4uA on a digital multi-meter. I was hoping to confirm/verify my results.
Somehow the lines have disapeared and i can now see a continuous signal, but I still can't see the difference when i connect the battery to the remote.
Perhaps I over estimated the sensitivity of the oscilloscope, it seems to go as low as 20mV/Div. I need something like 1mV/Div
I wouldn't go this way at all.
The standby current of remote controls is sub-mA you wouldn't be able to see any change in the Battery Voltage with a scope.
What you can do is use a sensitive Ampere-meter(μA).
If you don't have a digital one, you can use an old analog Ampere-meter or just a "bare meter"(50μA FS).
Or a sensitive DVM(μV scale preferable ) with say a 1-ohm or 10-ohm series resistor to measure the Vdrop on the resistor and calculate the current.
e.g assuming your Stby current is 100μA
you would get a 100μV with 1-ohm and 1mV with 10-ohm.
Yeah think your right dorke, isnt going to work out.
I have already obtained some results in (μA) using a multimeter.. this will have to do!
