J.Shrum
Greetings.
I'm currently working on a project that requires recording multiple audible
frequencies to the same audio file. Basically I'm recording the tone and
monitoring the freq spectrum for freq changes over a long period of time.
I'm using a 555 to produce the tone, since its frequency changes as the
condition of what I'm monitoring changes.
My issue is, when I view the spectrum, I end up w/ all of the harmonics. I
am wanting to remove these harmonics so I can use that bandwidth for other
tones simultaneously. Therefore I'd be able to monitor several sensors at
once... each sensor consisting of the same 555 circuit of course.
I realize I could use a notch filter on every oscillator, but I'm wanting to
see if there is a different way of filtering the harmonics, or even a way to
produce the tones w/out even creating the harmonics.
I was considering using an electret mic element coupled w/ a transducer
assuming that the harmonics wouldn't be broadcasted to the mic. But I don't
know if this will work.
Any thoughts? Any help would be appreciated.
Thanks as always
J.Shrum
[email protected]
Thanks as always
J.Shrum
[email protected]
