While trying to revive a component section of a 1979 Pro 222 Baldwin electronic organ, I cleaned connectors and pins on 5 of 23 daughter boards using contact cleaner.(This was successful frequently in the past) Prior to that, the remaining sections of the organ operated normally. After reassembling the daughter boards to the motherboard the organ did not play at all. Inspection of the main power supply revealed 2 overheated resistors and an overheated transistor. A schematic, PC board, and photo of the power supply with the current measured voltages adjacent to the correct value is shown. Also shown are the overheated resistors and transistor. Hard to believe this failure happened just as I was cleaning the 5 boards. Can’t imagine how I could have caused a power supply failure. Can anyone suggest which power supply components have failed? Appreciate any help I can get.
Thanks,
Jim B
Thanks,
Jim B
