Beachcomber
Here in Oregon, when conductors are brought from the top of the pole
to an underground cable at the bottom of the pole, the PVC enclosure
of the conductors is mounted on standoffs of what looks like 4 - 8
inches so that the PVC (or whatever material is used) is not actually
touching the pole except for the supports. I have seen this done for
high voltage distribution (34.6 kV) but also for household service
entrances (240/120 V) voltage levels.
I'm curious to know why the standoff from the pole, I haven't seen
this in other states. Anybody know for sure?
It seems obvious that this is to protect the wooden pole some way, but
from what? Because of the cooler climate, Oregon has comparitively
less lighting than most other states. Many transmission circuits are
run without grounded static wires because of this. Does the standoff
make it easier to replace a damaged pole? Is it somehow a safer
installation?
Beachcomber
installation?
Beachcomber
