OrCAD PCB Designer Mirror Object
For some reason i can't post in cadence forums access is denied, so i thought i could post here.
How to mirror a transistor whitout changing layer ?
When i mirror a transistor or other component it always change layer, so if its on top it flips to the bottom, but i just want all the components on the top layer, not in the bottom.
Rotate or Spin comand does't work because i want to switch the base of a transistor with the emitter, for example if its placed like this "B - E" i want to change to "E - B".
"Do not use the Mirror command, which is different from the commands in Capture: Here is means that the component should be placed on the bottom of the PCB rather than the top. Our designs are not that ambitious."
Other problem is on the Menu -> Route -> Connect F3, when i connect any component it connects whit a green color (which means is on the top), but i wan't to route everything on the bottom so the color should be all yellow, but i don't know how to do that, in which menu i can configure this?
