Mike V.
I've seen microcontrollers coupled to a DC motor controlled by
H-bridge drivers (from vendors like International Rectifier, Intersil,
SGS-Thomson, etc.) When it comes to low voltage motors (e.g. 24V), the
motor, microcontroller, bridge driver, and MOSFETs/IGBTs all share a
common ground.
I always thought that when you moved up to higher voltage motors, it
was desirable to isolate your micro's 5V ground from the
driver/fet/motor's ground with optoisolators.
Now, i've seen reference designs and reference boards that have up to
600V DC voltage rails with FETs/IGBTs and bridge drivers NOT isolated
from the digital 5V microcontroller ground.
What is the proper way to do things??
common ground.
