Newbie to the forum -please be gentle and forgive any unintentional etiquette breaches!
No electronic knowledge or theory but keen to learn.....
I'm a guitarist in a band and we have a small lighting rig run by a DMX controller but i've been trying to find a way to operate it using footswitches to select the various pre-programmed lighting 'scenes'.
so - bought cheap used controller looked inside and saw the scene selector buttons seemed to be mini momentary contact switches. - I thought 'if i soldered leads to the contacts and fed them to momentary footswitches i could mimic pressing the buttons to select the scenes and also change the 'banks' up and down' (8 scenes to a 'bank')
That way i could select lots of different lighting programs using the footswitches
The theory was to feed the leads in the controller to a DB25 pin socket - ad do the same thing using an old food warmer to construct the foot pedal with 10 switches - then connect them using a DB25 cable and hey presto!
Hmmm..Worked with some scenes (3,4,6,7,8) but 1&2 activated scenes 7&8 and 5 activated the 'blackout
and..... this also happened when pressing the buttons on the controller with the DB25 cable plugged into the controller but NOT into the footswitch (but works fine manually when no cable connected) - have checked connections several times
Pics below may show what i've done (soldering has been done and re-done several times so is not as tidy as it was at first !)
Thanks for reading and any ideas what is going on (words of one syllable please
