Opamp wanted
  • Thread starter Bearplug Bearplug Bearplug
  • Start date
I need a single/dual opamp for an audio buffer stage in a DIP-8 package.
Pinout is flexible, supply is +/- 18V. It has a drive capability similar
to NE5534/5532, but with FET input. Availability from Digikey or Mouser
and low cost a plus.
Suggestions? TIA.
Regards,
b
Phil Allison
"Bearplug Bearplug Bearplug"
Pinout is flexible,
** All 8 pin DIL dual op-amps use the same pin out.
** A supply of +/- 18 volts is really too high for most op-amps -
particularly the NE5534 /32 types.
Life will be short if you insist on that voltage.
The TL072 meets the spec you posted.
What do YOU imagine is so special about the " drive capability " of the
5534 or 5532 ??
Audiophool bullshit aside.
..... Phil
Date: Mon, Sep 7, 2009, 8:37pm (PDT+17) From: [email protected]
(Phil Allison)
voltage.
I see it routinely used. Don't know about mortality data. Anyhow, I'm
trying to avoid the 5534/32. The opamp in this spot is a non-inverting
buffer fed by a 50K pot. I'd like to not load down the pot, and avoid an
input cap.
you posted.
It'd be fine, except the 5534/32 is spec'd for 10V out into much lower
loads. The one in question is a tone control network with about 1K input
Z.
5534 or 5532 ??
Adequate current drive for a nasty load. My audiophool instincts rule
elsewhere.
Regards,
b
B.
Phil Allison
Phil Allison
**A supply of +/- 18 volts is really
voltage.
** No you fucking don't.
** Don't know much - do ya ??
Anyhow, I'm trying to avoid the 5534/32.
** Yawnnnnnnn....
input cap.
**The TL072 meets the spec you posted.
loads.
** No it is not.
The one in question is a tone control network with about 1K input Z.
** No problem for a TL072
- it will drive 1kohms to full out.
5534 or 5532 ??
** 1kohms is not a "nasty" load.
My audiophool instincts rule elsewhere.
** Gobbledegook.
...... Phil
Rich Grise
[/QUOTE]
Holy Crap! There's still "Web-TV"??????
Suggestions? TIA.
TL082?
Have Fun!
Rich
Jamie
Suggestions? TIA.
Regards,
b
TL081ACP
at http://www.mouser.com
Date: Tue, Sep 8, 2009, 9:34pm (PDT+7) From: [email protected]
(Rich Grise)
"Web-TV"??????[/QUOTE]
I'm the last surviving Webtv subscriber, now residing in the Cincinnati
Zoo. My daily diet is pureed bananas, sunflower seeds, and the
occasional human finger.
Soon the curtain will fall on my brief role as an evolutionary step.
I flung doo, but dreamt of flying.
