Hi, I am using a classic opamp integrator, my input is a 500us pulse at
a freq. of 80hz. The signal can vary in amplitude from several mv to
about 8volts.
The integration time is 10ms, which is about 20x longer than the
expected input. I noticed, if the input voltage exceeds ~4 volts, a dc
offset appears
at the output and increases as a function of input voltage. To mitigate
the problem, I placed a 75k resistor across the .1uf, to discharge the
cap before the next pulse. The integrator's C=.1uf and the r=100k.
I have several questions:
Would it be better to increase the time constant, rather than placing a
resistor across the integrator cap?
As far as integrating cap's is there a specific type used, is ceramic
ok?
I can provide a 5volt logic signal at the proper time for to control a
switch
which would discharge my cap, can a device be recommended?
thanks boats_ranger
about 8volts.
offset appears
ok?
switch
thanks boats_ranger
