Op.Amp:integrator and offset/Ibias errors
negromonte1
I have an home work to do:
http://img372.imageshack.us/my.php?image=integrator12ww.gif
At t=0+ the switch is open; at t=0- switch
is closed (vc=0). Calculate vo(t).
According the book the result should be:
vo(t) = VOS + (VOS/RC)*t + (IB2/C)*t (when t>=0)
But my guess is:
vo(t) = ± (VOS/RC)*t ± (IB2/C)*t (when t>=0)
(± sign, since neither VOS nor IB2 sign are predicible)
I don't understand the result of the book;
how that VOS (first term) can be in vo(t);
since amp.op. is in common mode range I used
"sum of effects" to calculate vo(t) and
according to me the contribute to Vout of
VOS is just to charge capacitor.
Thanks in advance for the help.
F
Fred Bloggs
But my guess is:
When the switch is closed vo=v(-) which must be at VOS for v(+)=v(-).
And when the switch opens this condition still holds for v(+)=v(-) so
that vo= VOS + q/C, at each instant by simple sum of voltages around the
loop, where q is the time integral of current from vo to v(-) node
through C. The current required to maintain v(-) at VOS is just IB2 +
VOS/R1, a constant supplied through C, so the integral is then
q=(IB2+VOS/R1)*t making vo=VOS + IB2/C*t + VOS/(C*R1)*t.
John Popelish
But my guess is:
The sign of VOS and IB2 are included in the symbol. In other words,
those variables include both a magnitude and a sign, just like any
other algebraic variable. Your method is more confusing than helpful.
Solve for the case when the switch is closed. That is what you start
with at t=0, before the capacitor has a chance to change its voltage
(integrate) at all.
