op-amp difference amplifier
please help me in designing a simple opamp difference amplifier where my inputs are v1, v2, v3 and my output should be av1+bv2-cv3 and a,b,c are any values .. i am doing it on my own interest.. i have tried it in many ways .. but i cant get my desired output... please help...
i have attached my circuit.. ignore the values in it
i got the eqn..
v0=(R2/R1){ [ (1+R1/R2)/(1+R4/R5+R4/R3) ]V3 + [ (1+R1/R2)/(1+R3/R5+R3/R4) ]V2 - V1 }
i am not getting my desired ratios here.. am i correct in this approach?
THANKS IN ADVANCE ..this is my first post.. pls forgive me if anything is wrong..
Letting Vi be the voltage at the op amp inputs, there are 2 node equations:
(Vi-V2)/R3 + (Vi-V3)/R4 + Vi/R5 = 0
(Vi-V1)/R1 + (Vi-Vo)/R2 = 0
Substituting to eliminate Vi gives:
((V1/R1 + Vo/R2)/(1/R1 + 1/R2))(1/R3 + 1/R4 +1/R5) = V2/R3 + V3/R4
Solving for Vo gives:
Vo= -V1(R2/R1)+(V2(R4R5(1+R2/R1))+V3(R3R5(1+R2/R1)))/(R3R4+R3R5+R4R5)
Did you start with the same node equations? I can't tell whether your Vo expression is the same as the one I derived. What desired ratios are you looking for?
thank you sir... i want output in format av3+bv2-cv1 , in which i should be able to manipulate for any values of a,b,c... (i.e) for eg, if i want 2v3+3v2-v1 .. the circuit should be able to give the output in the same ratios... will the circuit suit my requirement ? please help..
If you will notice, my expression for Vo is in the form:
Vo= -cV1+bV2+aV3 where (if my derivation is correct),
c= (R2/R1)
b= (R4R5(1+R2/R1))/(R3R4+R3R5+R4R5)
a= (R3R5(1+R2/R1))/(R3R4+R3R5+R4R5)
Your task, after verifying the derivation, is to select values for R1, R2, R3, R4, & R5 that will make c=1, b=3, a=2, for your example. Good luck, it may not be possible to have "any values of a,b,c" since this circuit would normally be used in a configuration where a=b=c.
