So I'm trying to come up with a topology for a linear current source with decent precision (~0.5mA/Vin) and range (0.5mA-500mA). I've been using one from TI, but I thought it would be fun to try and come up with my own, and for this project I have the luxury of doing so. This is what I came up with:
(note G is for gain of the IN-AMP and not conductance). Both opamps have +/- 15V supplies, ZL is an inductor with an impedance between 10 and 20 ohms, and Vin is a 10V amplitude sinewave between 2Hz and 512Hz.
A couple strange things, though:
This op-amp is in a noninverting amplifier configuration, and yet seems to be capable of gain of less than unity.
Also, I tried simulating it in SPICE and the results are basically no current. Parts will be arriving soon so I can actually try and build it, but what should I be aware of before I do? I've only been using basic op-amp theory and taking into account input bias currents and input offset voltages, but I understand there is a lot more that needs to be taken into consideration. How might I asses this circuit's stability? I tried calculating loop gain Aβ and it looks to be between A*0.05G and A*0.1G, which satisfies the approximation to estimate the closed-loop gain as 1/β, which would be about 10/G. I'm a little uncertain about where to go from here and how to go about assessing stability. I'm going through app notes from TI and AD, but they don't mention active components in feedback loops. Maybe because it's a terrible idea? I'm not sure.
