I need help with a circuit design for an effects loop in my tube guitar
amp. Because I don't have space for another tube, I'd like to use an
op amp based circuit. However, my knowledge re: op amp circuit design
is limited - I'm a tube guy....
After poking around I found this schematic:
http://www.drtube.com/schematics/marshall/pcbp-00119-60-02.pdf
Is this a reasonably decent design to clone?
I think it would work well for me since it was designed for an
amplifier very similar to mine and doesn't require an additional power
transformer; just step down the 380VDC rail (B+) voltage with a power
resistor and let the regulators do the rest.
Are there any easy improvements that could be made to this design? Am
I right to think it would be improved by using 7815 regulators over
Zener diodes and, by using an improved op amp (Analog Devices OP249)?
Any help is appreciated!
Eric
FWIW, an effects loop allows one to insert a low impedance signal
processor into an optimal section of the amp's high impedance signal
path.
Eric
path.
